Digital I/O
push button on digital port
    I'm trying to use a simple push button on a digital port line on a 6225 card without using an external pull-up (really, a simple on-off switch).  I can plug the switch with a coax on an interface connected to the digital port.  For now, I would only poll this port.  What I want to do is that if the button is open, the voltage read from the port should be 5 volts and when the button is close, zero volt.  I tried setting the starting state to 1 (TTL high, 5 volts) for this port but this doesn't seem to work.  Maybe I'm missing something and being thick but I have no luck for now.  Thanks for any advice you should have.
[Edit] Programming on Labview 2009
Salutations,
Michel
(4,828 Views)
Hi Michel,
Are you trying to write to or read from a digital port line? I would really appreciate it if you could clarify what your goal is. In the meantime there are some great examples that you can find here: LabVIEW>Help>Find Examples...     Hardware Input and Output>DAQmx
Cheers,
Carisa
(4,810 Views)
Hi Carisa,
    Just plugging an on-off switch to the digital line (DIO0 - DGND) without an external pull-up.  If the switch is open (normally this would be the case),  I should read 5 volts from the DIO0 line.  If the switch is close, I should read 0 volt.   As previously stated, the card is a PCI-6225 (but I could also use a PCI-6229).  Is that possible or I really need an external pull-up?
Thanks again,
Michel
(4,800 Views)
Hi Michel,
In this case, I believe you would need an external pull-up resistor. Hope this helps!
-Carisa
(4,787 Views)
