Digital I/O
Is there a way to tell if I have 6533 or a 6534 board?
When I look under the Measurement and Automation Explorer it just lists them as PCI-32HS.
I want to do continuous outputs, and I believe I need the 6534 for that.
(3,493 Views)
Hi Matt,
Do you have the part number for the card?  It will be something like 778287-01 (not the same but a 6 or 7 digit code followed by a -01 or -02).  If I know this number, I can take a look in our system to find out what it is.
Jim Schwartz
(3,471 Views)
From here it looks like you have an answer.
Well- between that and the help file here
 The PCI 6533 shows up in MAX as PCI-DIO-32HS
the 6534 shows up in MAX as a PCI-6534
 I don't know why NI does this but it's pretty confusing.  Maybe having the quick-start guides online would hel.
Still- NI has the best support just, not perfect Smiley Very Happy
(3,458 Views)
