Digital I/O
error - 1074118624
Hi all, I'm using a PXI-6551 card.
I would like to ask if the output of the card is shorted, will I get the error msg as below
error - 1074118624 occurred at HSDIO Fetch Waveform (WDT).viDriver Status: (Hex 0xBFFA4020). Some or all of the samples requested have not yet been acquired. To wait for the samples to become available, use a longer read timeout or read later in your program. If your session uses a trigger, make sure that your trigger is configured correctly.
Thanks.
(3,567 Views)
I don't think this error has anything to do with an output.
It causes from fetch waveform is timeout before all required samples are available.
Set a longer timeout should solve a problem.
(3,556 Views)
Hi simjianyou123,
Did you ever resolve this problem?
Keith Shapiro
National Instruments R&D
(3,473 Views)
