Digital I/O
LV application builder v7.1
I am trying to make an exe file of a function block with the LV Apps builder v7.1 (for Window 2K/NT/XP)...but I am getting this following message at the before I click the finish button at the end...
Installation Summary
No software will be installed or removed.
Does the mean that it is already installed? If so, how can I locate this application?
any ideas??
thanx,
(3,502 Views)
This is typically the message that a Windows installer gives you when you attempt to install an application that is already installed. You can get a list of applications installed on a Windows system by going to the Control Panel and selecting Add/Remove Programs. Also, if you know the name of the executable (i.e. "VIname.exe"), then you can simply search your hard drive for it to find its location.
P.S. In the future, you should try to post pure LabVIEW questions to the LabVIEW board. This way your question will get more exposure among experts in that field!
Kind Regards,
E. Sulzer
(3,494 Views)
thank you!
(3,474 Views)
