Digital I/O
Level-ACK with NI-DAQmx?
Is it possible to configure a DIO-32HS with Level-ACK mode with NI-DAQmx 7.4? All that I see is "Handshake (8255... )" when I try to select a NI-DAQmx Timing.vi. If it is possible, how does one then set the ACK Delay?
Bernd
(3,655 Views)
Bernd
Use the DAQmx Timing (Handshaking).vi and these properties:
Try these settings:
For Input tasks:
PropertyValue
DAQmx Timing : Hshk.StartCondWait for Handshake trigger asserts
DAQmx Timing : Hshk.SampleInputDataWhenHandshake Trigger Asserts
DAQmx Timing : Hshk.DelayAfterXfer100 ns
DAQmx Trigger : Hshk.Interlocked.AssertedLvlHigh
DAQmx Export Signal : HshkEvent.OutputBehaviorInterlocked
DAQmx Export Signal : HshkEvent.Interlocked.Deassert Delay100 ns
DAQmx Export Signal : HshkEvent.Interlocked.AssertOnStartT
For Output tasks:
PropertyValue
DAQmx Timing : Hshk.StartCondImmediate
DAQmx Export Signal : HshkEvent.Interlocked.AssertOnStartF
You may need to lengthen the Deassert Delay to fit your device. You may need to change the polarity of the handshake trigger (Hshk.Interlocked.AssertedLvl) or the handshake event (HshkEvent.Interlocked.AssertOnStart)
Jeff
Message Edited by jcarbonell on 06-08-2005 02:35 PM
(3,631 Views)
