Digital I/O
pci dio32hs
Hello every one
I need some help. Indeed, i already used three pci-dio-32hs cards, and they did work. But today, i try to use Measurment&automation explorer in order to test all the card, and the card number two had dissapeared. (I only had the card number one and three...). Does that mean the card number two is broken and i have to change it?
I use windows2000, and i haven't touch the cards and the drivers, and this sytem was ok last week.
thanks for your answers.
hervé
(3,176 Views)
Try to see if the board is correctly installed on the PCI slot. Try to test the board on another PCI slot and on another PC. If the board is not recognized each time in the Windows Device Manager and also in MAX, the board need to be returned for repair.
Regards.
Matthieu G.
AE, NI France
(3,164 Views)
