Digital I/O
Logic Analyzer vi?
Hi guys,
I want to analyze the logic behind a number of digital lined being fed into my PC. Is there any sample Logic Analyzer vi which I can make use of to figure out these signals?
I am using the PXI-7813R or specifically its FPGA to develope the program.
(5,725 Views)
Hi The_Sugarman
What data are you feeding into your PC?
How is this data connected to the PC?
Have you connected some external device to the PXI-7813R which you are then trying to use to read those digital signals with?
If you want to read the digital input to your PXI-7813R then you should take a look at %Program Files (x86)%\National Instruments\LabVIEW 2012\examples\R Series\Basic IO\Digital Line Input which shows how a digital input can be read on your R series card.
Kind Regards
Chris | Applications Engineer NIUK
(5,697 Views)
Hi Chris,
Thanks for the reply.
I want to feed in a number of seperate digital signals (betweem 4 and 6 seperate lines) from a device that has no controller in it. It is in effect a "dumb" chip that has a memory.
I plan to connect the data through a SCB-68 connector, through the PXI and then to the PC through the MXI card within the PXI.
So far, no, I have not connected any external device. Interestingly, I had to change my plans from the original project I was working with becasue I couldnt read the data from an external device. In the original project, the external device is a smart printer that I have been using to read in the signals from the inkjet cartridges connected to the printer. But thats another project, if you need more info on either, let me know.
(5,657 Views)
