Digital I/O
Hardware Problem with PCI 51222
I was using my PCI 5122 and suddenly the card did not work anymore and showed me the following error:
Possible reason(s):
Error:  -239022 occurred:
Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support.
Elaboration: Component Name: nimxslu proxy
File Name: This is NOT an error in nimxslu. See nimxsl/tStatus2KernelProxyWrapper.cpp for information
Line Number: 290
Status Code: -239022
I already restarted the computer, but it still does not work. Next, I tried the card in a different slot, still the same error. Lastly, I updated the NI-Scope software to it's latest version 4.0, still the same error.
This already happened twice with our PCI 5122 card. I hope this issue can be fixed soon.
All the Best,
Ann-L
(5,588 Views)
Hello Ann-Lauriene,
This is a documented error that indicates a fairly general problem that may be caused by either hardware or software. In order to troubleshoot this issue efficiently, I would like to recommend that you call in to our Support team so that we may assist you appropriately. Please use the link below to find the contact information necessary to reach our Support department.
http://sine.ni.com/apps/utf8/nicc.call_me (Contact NI)
Wes W
Application Engineering
www.ni.com/support
(5,567 Views)
