Digital I/O
Low frequency measurement with digital input
I started using LabVIEW recently and I would like to know if it is possible to calculate or measure the frequency of a digital signal (pulse train) using a regular digital input (no counter or analog input available). I have a cDAQ with an NI 9425 module. The characteristics of the pulse train signal that I'm trying to measure are: Frequency = 100 Hz, Duty cycle = 50%.
Any help or example would be appreciated.
Thank you.
(1,380 Views)
You can capture the digital waveform and post-process it for frequency.
Santhosh
Soliton Technologies
(1,341 Views)
Thanks for the advice. This is the built example that worked for me.
(1,327 Views)
