01-28-2023 05:33 PM
I was using NI USB 6008 with MATLAB and it worked great. Then I downloaded labview and the driver has vanished. Where can I find just the driver?
01-28-2023 08:08 PM
So, there is a special order of installation for NI software - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8aNSAS&l=en-US
Always install LabVIEW first and then the driver next, in your case, you already had a driver before LabVIEW and hence it will not show up in LabVIEW.
What versions are you using?
01-28-2023 10:46 PM
Thanks for the info that will help. What I really need to know is what is the driver called (file name) and where can I find it?
01-29-2023 12:13 AM
USB-6008 requires NI DAQmx drivers, you can download from here - https://www.ni.com/en-us/support/downloads/drivers/download.ni-daqmx.html (looks like the page is down)
