Digital I/O
MAX doesn't recognize DAQCard-6533, but windows does
I followed the instuctions to install the card exactly.  I installed all the software and then the hardware.  Windows recognizes my card and claims it is working correctly, but Measurement and Automation explorer does not even detect the card.  The only option under devices and interfaces is PXI System (Unidentified), which showed up after installing the hardware.  How can I make sure my card is detected and working properly with Measurement and Automation explorer?
(3,331 Views)
Do you have the Traditional NI-DAQ (Legacy) driver installed? This device is only supported for Traditional NI-DAQ. A good way to check if the driver is installed is to expand the softare tab in Measurement and Automation Explorer (MAX). Let me know if you do have the driver and you still cannot see your device in MAX.
Hal L.
(3,317 Views)
