Digital I/O
error -10401 (unknown device) when driving daqpad 6508 after power down
I'm currently using a DAQPAD 6508 to do some IO. This is working OK exept for one thing:
When the PC which is using the DAQPAD is rebooted, a "-10401" error occurs (unknown device) !!! This error occurs in the DIO
This persist until I open Measurement explorer and open the Test Panel and do some random settings. When I then run the application again, everything works...
Remark that the DAQPAD 6508 is driven though USB.
Attached you'll find the vi that I use to drive this device...
thanks in advance for the help...
(3,601 Views)
Hello beeuwke,
You can have a look a this link. Maybe it will help you.
http://forums.ni.com/ni/board/message?board.id=70&message.id=4315&requireLogin=False
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(3,585 Views)
Hello beeuwke,
Any news about your problem? Solved?
Keep me informated.
(3,555 Views)
thanks for the answer...
I had a look at the discussion but that wasn't my problem...
I then posted a message on the following discussion:
There, I had some kind of answer to my problem. I need to powercycle my NIDacpad to get rid of the 3 let blinks and I needed to install a newer version of NIDac drivers... which helped a lot.
thanks,
best regards,
Marino
(3,547 Views)
