Digital I/O
Manual control pulse generation
Hello, Labview community.
I'm sending a 5V signal to my multiplexer reset terminal physically with a toggle switch. Toggle ON, it stays high 5V, toggle OFF, it stays low. Can someone share an example which does the same work using NI 9401, manually control from the front panel? Thanks in advance.
(2,507 Views)
Accepted by topic author Xiao@Gemini
Problem solved.
(2,493 Views)
