11-19-2018 09:09 AM
Hello, Labview community.
I'm sending a 5V signal to my multiplexer reset terminal physically with a toggle switch. Toggle ON, it stays high 5V, toggle OFF, it stays low. Can someone share an example which does the same work using NI 9401, manually control from the front panel? Thanks in advance.
Solved! Go to Solution.
11-19-2018 11:02 AM
Problem solved.
