Background:
During a system test, wires were inadvertently reversed and 24V DC was applied to all the COM lines on the 9401 and to DIO 4, 5, and 6. Thus pins 1,3,4,6,7,9,10,12,13 (all the COM lines are bussed together in our 25pin DSub) and pins 20,22, and 23 were all raised to 24V. Te other inputs were floating (not connected). The module is now non-functional. It self tests ok, but when you turn on the test panels, none of the DIO's will work as either inputs or outputs anymore. So we blew the module. It's dead.
What we want to do:
We are considering ways of modifying our wiring harnesses such that if 24V is applied to the wrong wires while it's hooked up, the module will be protected.
My questions:
If we place diodes (probably 40v
Schottky's) on the DIO pins, this will theoretically protect our output channels from being driven by some external source, correct? But will the module still be blown by a voltage on the COM lines? How much can COM be safely driven away from the power supply ground of the compactDAQ carrier board without blowing the module? How much current can COM sink without burning it up? Do you think it was the voltage on the DIO pins that killed it, the COM pins, or both? Anyway, we want to make sure this doesn't happen again.
Thank you for any suggestions.
Walter
