Digital I/O
NI-6514 - DAQ Task - Error 200077
I'm trying to create a simple task that outputs a 50 Hz step function for either N samples or continuously, it doesn't matter at this point.
I seem to get this error for any Generation Mode or Clock Setting when I click Test.  What am I missing?
(3,395 Views)
Actually, it looks like the problem is that you are trying to do a hardware timed generation with a board that does not have timed digital I/O.  The 6514 has static digital I/O only, which means that you are confined to using 1 Sample (On Demand).  If you would be interested in recommendations on a board that does have hardware timed digital I/O then please let me know what your needs are as far as channel count, isolation, etc., and I can make a recommendation for you.
You can create a program that does software timed digital output if you do not need a very fast update rate.  However, this is not recommended because the timing will not be deterministic unless you are on a real time OS.
I hope this helps, let me know if you have any questions.
(3,369 Views)
