Home
Community
Discussion Forums
Most Active Hardware Boards
Digital I/O
Topic
Digital I/O
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Memory is Full
Memory is Full
Michael Parker
03-11-2005
02:32 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Using the build Array Function.
Using the 6533 I/O Card.
0
Kudos
Message
1
of 4
(3,537 Views)
Reply
Re: Memory is Full
Alex_S1
NI Employee (retired)
03-14-2005
10:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Can you provide a litte more information about your program?
It sounds to me as though you're probably using the build array function inside a loop which could be causing the problem.
~Alex
0
Kudos
Message
2
of 4
(3,513 Views)
Reply
Re: Memory is Full
Michael Parker
Author
03-14-2005
11:26 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thank you Alex,
I solved my problem is was a missing variable that I forgot to reset.
Mike
0
Kudos
Message
3
of 4
(3,503 Views)
Reply
Re: Memory is Full
Alex_S1
03-14-2005
12:08 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You're very welcome, congratulations on the fix.
0
Kudos
Message
4
of 4
(3,498 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
