Digital I/O
Memory is Full
Using the build Array Function.
Using the 6533 I/O Card.
(3,536 Views)
Can you provide a litte more information about your program?
It sounds to me as though you're probably using the build array function inside a loop which could be causing the problem.
~Alex
(3,512 Views)
Thank you Alex,
I solved my problem is was a missing variable that I forgot to reset.
Mike
(3,502 Views)
You're very welcome, congratulations on the fix.
(3,497 Views)
