Digital I/O
My client uses digital.llb with a vi called "DIO Stop.vi". Where is that?
Client started with LV version 6.0. This LLB was present with the vi called DIO STOP.VI...Later upgrades do not include this file. Why? Has it been replaced? What did it do...does it still need to be called? Current application will no compile because this vi is not found.
Thanks!
(3,180 Views)
I am not aware of a built-in LabView vi called "DIO Stop.vi" (not in versions 5.0 thru 7.1)
It must have been implemented by the programmer.
Open the LLB manually and see if the file exists. If it exists open it, then open the main vi
If you do not find it or if it got corrupted, use the version 6 of the LLB assuming it is aviilble, open the vi, and save it to a new destination.
(3,174 Views)
