Digital I/O
NI 9401 velocity update problem
I am using NI 9401, and configured it to Quadrature mode to measure speed of a motor.
The sample rate is set to 2ms. I use a TDMS file to store data, those data are input voltage, speed (in rad/s), and time (ms).
It seems the update rate of the velocity is very low, 10ms, that is 100Hz. I don't know why. Does anybody have the problem or any solution?
Thanks a lot.
30.67961576 3 9616682
30.67961576 3 9616684
30.67961576 3 9616686
30.67961576 3 9616688
30.67961576 3 9616690
76.69903939 3 9616692
76.69903939 3 9616694
76.69903939 3 9616696
76.69903939 3 9616698
76.69903939 3 9616700
117.6051937 3 9616702
117.6051937 3 9616704
117.6051937 3 9616706
117.6051937 3 9616708
117.6051937 3 9616710
153.3980788 3 9616712
153.3980788 3 9616714
153.3980788 3 9616716
153.3980788 3 9616718
153.3980788 3 9616720
178.9644253 3 9616722
178.9644253 3 9616724
178.9644253 3 9616726
178.9644253 3 9616728
178.9644253 3 9616730
204.5307717 3 9616732
204.5307717 3 9616734
vivozhang
(5,518 Views)
I finally found the problem, the default scan engine clock is 10ms, so...
vivozhang
(5,500 Views)
