Digital I/O
NI-9472 and Vsup, overvoltage and output forced high
I am bout to buy an NI-9472 module. I will use it with a 24 V DC power supply in order to control a few relays.
I see that the module has a 30 VDC safety voltage on I/O pins, but what if power to cDAQ is turned off when Vsup is still on? Does the module get damaged or can it whitstand those 24 V DC even when turned off?
A second question: can I use a button in parallel to an NI-9472 output in order to force that line high (at 24 V) even when the module is requested to keep the pin low? In other words, what happens if I try to force a pin high in hardware, when software (Labview) tells it to keep low?
Thanks in advance for your help.
Stefano
(1,448 Views)
Accepted by stinf
Given there is no explicit detail of how the protection differs between powered and unpowered, I assume both are the same.
For your second question, 9472 is sourcing output module, this means, it can only source a voltage and not sink it, in other terms it cannot pull the output low, so, connecting a switch to override the load should not affect it as it would not attempt to sink any current within the protected voltage range.
Santhosh
Soliton Technologies
(1,426 Views)
Hi santo_13, thanks for your help!
(1,385 Views)
