Digital I/O
NI-DAQ-connection to acquisition board was not found
It sounds like you have a problem with windows and file associations.Talk to your IT department. The current version of the configuration utility is called NIMAX.exe but I have no idea what it was called on such an old os.
So, you decided not to use the most current version and instead you are trying 6.5.2?
Message 11 of 15
(2,279 Views)
Respected Sir,
I try the possibility to work in labview 5.1 operating windows 95 version.
I will solve windows probelm and contact you soon.
Thank you for your immediate response.
Yours friendly
m. vijay
Message 12 of 15
(2,276 Views)
Respected Sir,
I got labview 8.2 version which is compatability with labview 5.1.
So i installed labview 8.2 operating in XP.
I am using Field point hardware FP 1000, so i installed field point 5.0.1
In my old labview 5.1, Ni-DAQ 6.5 was used.
I would kindly request you to please tel me which NI-DAQ version for labview 8.2 and also compatability to support hardware already used  in 5.1 version.
Thnaking You
Yours faithfully
M. Vijay
Message 13 of 15
(2,269 Views)
Respected Sir,
Today i got MAX in desktop, By installing NI-DAQ 6.5.2.
wIll you please help me how to configure and test an NI DAQ board by MAX.
Thanking you
Yours friendly
vijay mani
Message 14 of 15
(2,249 Views)
Respected sir,
I am kindly request to help me to find NI-DAQ card suitable to my applications.
I am using labview 5.1, fieldpoint FP 1000, NI-DAQ 6.5, Field point explorer version 1.6, Measurement and Automation Explorer 1.0.1.
my probelm "connection to acquisition board was not found" when i run labview program is due to DAQ board was not there in my CPU, so o plan to purchase NI-DAQ board.
I also have labview 8.2 (since labview 5.1 compatability with 8.2), field point 5.0.1, NI-DAQ 6.9.3.
from the forum i read
NI-DAQ 700 card is used in  NI-DAQ  driver 6.6 on labview 5.1 operating windows 95.
also
NI-DAQ 700 card is used in  NI-DAQ  driver 6.9.3 on labview 8.2 operating windows XP.
The details of AT-AO-10
1. i found from device manager >> Data Acquisition system >>  AT-AO-10
2. also i found in MAX >> Deviec and interface >>  AT-AO-10 (Device 1)
configuring device 1: AT-A0-10
system
device No: 1
Resource
Input/output range 0* 140* - 0*15F
interrupt request  11
interrupt request  9
direct memory access 6
AO
polarity Bipolar
Output Channel type voltage
if i click run test panel
i received command as
The device did not pass the test would you like to continue anyway
if i click yes
test panel window is open
Device name AT-A0-10   Device No: 1
Analog output
DC voltage is selected
Digital I/O
line state       Fatal      Fatal                  Fatal
                      error       error                 error
line number   3              2             1           0
last error -10401
I would kindly request to help me.
Thanking You
Yours faithfully
M.Vijay
Message 15 of 15
(2,227 Views)
