Digital I/O
NI DAQ not reading or writing on one computer, but it does on the other.
On one computer my NI DAQ works perfectly, reads and writes with the NI MAX application. On the other computer I can't get it to read or write from the same port. I have tried switching cables, DAQs, factory resetting the laptop, and reinstalling labview. The DAQ connects just fine to the malfunctioning laptop, all of the information appears to be correct. But the digital read and write never changes from high on NI MAX.
(985 Views)
I didn't find issues according to your logs.
Could you help to describe how to test the IO? did you try to connect 5V or 0V to the IO ports ? and GND is well connected?
Or is there something wrong with the DAQ driver?
(928 Views)
