10-23-2007 08:35 AM
10-24-2007 05:08 PM
Hi Bill,
I understand that your PCI-DIO-32 and PCI 6071E are in one of the 12 slots on your industrial computer and working correctly except when you install the NI-VXI driver. This driver should not have any conflict with the NI-DAQ driver. NI-VXI driver calls are used for initializing and configuring your VXI system and should not affect the driver calls for data acquisition. What versions of NI-DAQ and NI-VXI did you install?
You mentioned that the Init_DA_brd function causes the application to hang. Are you using this function in a text based environment like CVI or a version of LabVIEW? Knowing more about your setup might make it easier to troubleshoot this issue. It might help to know why you need to use NI-VXI and how your system is configured. Do you have a VXI system connected to the industrial PC that needs this driver to run?
According to this knowledgebase, Order of Installation for Multiple National Instruments Hardware and Software Products , Traditional NI-DAQ should be installed before NI-VXI. You might then consider uninstalling everything again and starting the installation procedure over just to make sure that the driver software was not corrupted during installation. Please let me know if any of this was helpful or if you could provide me with some more information!
