Digital I/O
NI PCI-6519 what should I do with unused channels
I have a NI PCI-6519 with 32 channels but I need only 16 channels.
What should I do with the unused channels? pullup, pulldown or not connected?
Thank you
(3,221 Views)
I am not sure about this particular board but virtually all other i/o devices I have encountered have pull-up resistors on the input lines. This should be specified in the board description. So external pull-ups usually are not required, and you can leave the lines unconnected.
However, due to high input impedance (even with a pull-up) these lines may pick up noise and may accidentally be pulled down to the low level. If you want to make sure to avoid this, either tie all unused input lines to GND or use pull-up resistors with rather small values (in the 1 kOhm range).
(3,218 Views)
