Digital I/O
NI PXI 6561 Loop Back
Hi All ,
I have a question about NI PXI 6561 LVDS card...
I want to make a simple loop back to test the channels.
I'v connected CH0 to CH1 and used the static generation to try see if the connection is OK.
but when i'm setting CH0 to '1' and i'm doing aquire i only see '1' at CH0 and not in CH1...
Any idea's ?
Kobi Kalif
Software Engineer
(3,846 Views)
Accepted by Kobi_K
Hey Kobi,
As long as you are doing static generation, you should be able to see a high on CH1 if the cables are connected.  Check to make sure that 0- is connected to 1-, and 0+ is connected to 1+, and that the connections are complete and secure.
Jake G.
Applications Engineer
(3,831 Views)
hiiiii   kobi
I am doing also loop back test using PXI 6562 hsdio card. But I am not able to do it. I am generating dynamic signal & trying to read it. I am connecting two channels using sma male to sma male cable.
Can you share how you did it?
Is there something I need to take care about cable which I am using for transmitting signal?
Rahul
(3,474 Views)
