Digital I/O
NI USB-6008 and Linux Comedi compatibility
Hello!
Could you advise if NI USB-6008 compatible with:
- Linux Comedi driver
- NI DaqMx Base
If it is compatible, please give me the link(s) for the documentation on installation and programming.
Thanks in advance,
Vadim.
(5,948 Views)
Thank you for posting to the NI Forums!
I found a document online that lists the supported hardware for COMEDI. The USB-6008 does not appear to be a supported device. The 6008 is supported in the NI-DAQmx Base drvier version 3.2 for Mandriva,RedHat, and SUSE however. Hope this helps!
Margaret Barrett
Applications Engineer
Digital Multimeters and LCR Meters
(5,925 Views)
Thanks for the info.
I downloaded nimx base for Linux.
Unfortunately I can not install it on my OpenSuse 11.
When I run # ./install - the installer asks to  instal nivisa first.
When  I run # ./install in nivisa folder - te installer asks for NICVISA_.TZ file which is not included in the package.
Could anybody help with that please.
(5,916 Views)
Accepted by Vadim_I
Hi Vadim,
         Which version of DAQmx Base are you trying to install?  I would recommend installing NI-VISA first.  Please let me know if that doesn't work!
(5,890 Views)
Hello.
Thanks for guiding me through.
My success so far:
NI USB-6008
Linux OpenSuse 10.3 KDE
nidaqmxbase-3.2.0 installed
NI-VISA-4.5.0 installed
no USB mount on fs:
# mount
/dev/sda5 on / type ext3 (rw,acl,user_xattr)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw)
debugfs on /sys/kernel/debug type debugfs (rw)
udev on /dev type tmpfs (rw)
devpts on /dev/pts type devpts (rw,mode=0620,gid=5)
/dev/sda6 on /home type ext3 (rw,acl,user_xattr)
securityfs on /sys/kernel/security type securityfs (rw)
/dev/sr0 on /media/NIVISA450L type iso9660 (ro,nosuid,nodev,noatime,uid=1000,utf8)
no USB in proc
/proc/bus/usb # ls
/proc/bus/usb # dir
total 0
NI Visa Interactive Control can communicate with USB-6008. viGetAttribute works fine.
I compiled examples/ai/acquire1Scan and run it
Output - DAQMxBase Error: Device identifier is invalid.
I changed the line in code:
 // Channel parameters
 char        chan[] = "Dev1/ai0";
I changed Dev/ai to 0/0, 0/1,  1/0,  1/1 -  still  Device identifier is invalid.
Could you suggest what else can I do.
Vadim.
(5,871 Views)
Thanks a lot to everybody for assistance.
Finally I found the issue - it was old firmware on my USB-6008.
I used NI firmwareupdate utility and now it's Ok.
Vadim.
(5,858 Views)
