Digital I/O
NI USB 8451 with external power source
Hello everyone !
I try to figure for 2 days now why my USB 8451 gave me an error 301740 : SDA or SCL line or both are in a low state or there are no pull-up resistor.
I try to change a multiplexer channel in order to obtain a temperature mesurement from a sensor. I checked my SDA and SCL lines, thye're both in high state and i have 2 pull-up resistors with a value of 10K.
The only change with my older circuit is that  i use an external power supply for my electronic chip and a MUX PCA9543(texas instruments) to select the sensor of which i need the data .
Does anyone have encountered similar issues ?
(5,457 Views)
Accepted by topic author Sanguigui
Ok guys,
apparently, the ground of my usb 8451 wasn't connected to the ground of my power supply, it is not working yet but my components are responding !
(5,451 Views)
Everything is working fine with the tied grounds, Don't forget to do it!
(5,448 Views)
