 AshwiniWini
			AshwiniWini
			01-08-2025 11:52 PM
Hi all,
I am stuck and definitely use your help.
I am using NI 9401 on cRIO-9049 to read digital pulses generated by differential encoder. As 9401 is single ended TTL, I have connected only A and B signals (A- and B- are open). I am going to relace this module by NI9411 later. But for now, I have get this working.
I want to read pulses on FPGA using FPGA IO Node. I have connected encoder pin A and B to module's pin DIO5 and DIO6. This is how my chassis look like:
When I run FPGA vi, I can't read any data from these encoder pins. But if I go to NI MAX and run test panel by changing programming mode to 'Real Time DAQmx' while FPGA VI still running, I can see FPGA VI gets the pulses from encoder.
Can someone please help me to figure out what might be the reason for this behavior?
Thank you in advance.
Ashwini A Pandit
Solved! Go to Solution.
 ZYOng
			ZYOng
			01-09-2025 06:55 PM
Try setting the line direction using FPGA IO Method instead?
How Can I Programmatically Set Line Direction to Output with NI-9401 in LabVIEW FPGA?
01-09-2025 07:37 PM
Thank you ZYOng for the response.
I can't see FPGA IO method, looks like it is not supported for my target cRIO 9049.
01-09-2025 10:52 PM
I was able to set the line direction using FPGA IO Method on FPGA vi (previously I was trying insert FPGA I/O method node in real time vi).
But still having the same issue.
01-16-2025 08:55 PM
Hi everyone,
I just realized a mistake: someone used my setup and disconnected the encoder pins from the cRIO 🤦♂️.
When I was using the Test Panel in NI MAX, it was simulating data, which I misunderstood as real data.
Lesson learned: Always double-check your hardware connections, especially when sharing your setup with others. I learned this the hard way.
Thanks for all your support.
