Digital I/O
Need DIO for 3.3V outpus
6527 : isolated, higher max output current, 24 DIs and 24 DOs, up to 60V...
6501 : cheap, portable, easier to connect...
Message 11 of 12
(1,382 Views)
Hi Rafi,
The PCI-6527 is isolated for industrial applications with an output range of 0-60 VDC and can source much more current.  Because you don't need that range, the USB-6501 is probably a better choice for your application, but be sure to double check your current needs and make sure the USB-6501 can provide it, as it is bus-powered.
Message Edited by NI-Bongo on 02-25-2008 04:15 PM
John Bongaarts
Message 12 of 12
(1,376 Views)
