Digital I/O
Novice attempting to get a PWM square wave output from a 9401
I'm currently attempting a project in which I need to trigger a square wave output through the 9041.
The trigger is an "if" statement with-in my coding & dependant on the result this changes the duty cycle so that I can control a motor through PWM.
Originally I had intended on creating a digital output through one of the example files on the system ( Example Finder> Hardware Input Output> DAQmx> Digital Output ) & then gaining an understanding of how that one worked & creating my own.
However, even using the example "Digital - Continuous Output.vi" I am yet to see any sort of signal on my oscilloscope which I have the 9401 hooked up to.
I'm using the file as it stands, setting the lines to "cDAQ1Mod3/port0/line0", setting the clock source to be onboard the cDAQ (/cDAQ1/ai/StartTrigger) & seeing nothing.
I'm having some luck using the "Counter - Finite Output.vi" example but this is just giving me rising and falling edges which I assume are to be used as triggers.
Any ideas where I can start with this would be much appreciated.
(6,399 Views)
Hi crumpetnibbler,
Am I correct in thinking that you require a PWM output which allows you to change the duty cycle 'on-the-fly'?
The following White paper describes methods of outputting PWM signals using DAQmx and also has examples which include the functionality to trigger and alter the PWM duty cycle:
http://www.ni.com/white-paper/2991/en
I have tested this with a 9401 and have successfully generated a PWM signal.
Please note that DIO0 does not necessarily relate to ctr0 output. In order to see which pins should be connected, you can right-click the hardware in MAX and select Device Pinouts.
Please let me know if I have made any incorrect assumptions of if you have any further questions on this.
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(6,380 Views)
I could kiss you right now.
I haven't had a chance to test it because the only chassis I have available to me was in use but if you managed to get it working with a 9401 then I know it's possible & I'll just keep at it until I get it working.
I assume I just alter the "Counter(s)" parameter to be the pin output that I need & I can change the duty cycle as the program goes.
Thanks again, I'll report back when I get a chance.
(6,361 Views)
Hi Chris,
I've got the PWM program from the White paper working but when I hook it up to an oscilloscope I am not seeing a square wave, instead I'm seeing the following (apologies for the picture quality & unfocused reading on the scope, someone changed the settings while I was away)
The trailing edge moves when I alter the duty cycle so it works in that sense, I just assumed I'd be looking at a square wave. Is this correct or have I managed to go wrong somewhere?
Many thanks for any help,
Josh
(6,341 Views)
Try settting your scope input for DC coupling. It looks like you have it on AC.
Good luck,
Dave
(6,321 Views)
