Digital I/O
P65570
  I have an old pcb board. The only markings I see is 'P65570'. It's a board with a 50pin connector that is used to connect to a PCI-DIO-32HS board via ribbon cable.
Does anyone know if this board was ever made by National Instruments ?
I'm looking for a description/schematic of what this board does. Any help would be appreciated !
     ak
(5,791 Views)
Accepted by AKparts
The 'P65570' does not seem to match any of National Instruments' products. Can you locate the board part number, or its model number?
Tarek B
Applications Engineer
(5,776 Views)
  The "P65570" is the only information on the board...
I guess it's not an NI board.
 I wasn't sure if it was or not.
    Thanks for checking it out.
      AK
(5,765 Views)
