Digital I/O
PCI 2.1 Compliant card on PCI 2.2 Slot
Hi friends,
I have a query related to the PCI bus. I am ameatuer to this technology and so does require ur assistanace. I have 5 PCI cards that are PCI 2.1 Compliant 32 bit ,5 V power and signaling.  I am searching for some PC that meets the requiremnets for these cards. Most of the PCs that I could find are PCI 2.2 based slots.
My question is
1. Does the cards that are PCI 2.1 compliant work on PCI 2.2?
2. I searched some articles and found that from the PCI 2.3 the support for 5V card is removed. Does this mean PCI 2.2 supports 5V cards.
3. I could also find out thta PCI 2.2 require 3.3V signalling? What does this mean? Does this mean that cards that support 3.3 V signalling and 5V power could only work?
Thanks and Regards,
Sathya
(9,507 Views)
Hello Sathya.
Thank you for posting to the NI Discussion Forums.
In searching for the answer to your question, I came across a very helpful discussion forum at:
PCI Interface
Also, information about PCI 2.3 can be found here:
Conventional PCI 2.3
Feel free to look at these resources.  I think they will answer all of your questions.
Have a great day!
Brian F
(9,483 Views)
