Home
Community
Discussion Forums
Most Active Hardware Boards
Digital I/O
Topic
Digital I/O
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
PCI-6251, BIT Waveform, BIT width can be 333us ?
ateproject2007
Member
07-06-2010
10:51 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to use DIO of PCI-6251 to generate a bit waveform like the attached. The bit width is required to be 33us +/- 1%. Can it possible ? If ok, show me some vi examples .thanks a lot.
Visio-TEK BIT STREAM (2).pdf 20 KB
0
Kudos
Message
1
of 2
(3,179 Views)
Reply
回复: PCI-6251, BIT Waveform, BIT width can be 333us ?
Gavin_zhou
NI Employee (retired)
07-07-2010
02:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you can try the example below, this should be done by correlated DIO.
pwm_multdo.zip 49 KB
0
Kudos
Message
2
of 2
(3,168 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
