Digital I/O
PCI-6251, BIT Waveform, BIT width can be 333us ?
I want to use DIO of PCI-6251 to generate a bit waveform like the attached. The bit width is required to be 33us +/- 1%. Can it possible ? If ok, show me some vi examples .thanks a lot.
(3,269 Views)
you can try the example below, this should be done by correlated DIO.
(3,258 Views)
