Digital I/O
PCI-DIO-32HS: Continuous pattern I/O.
I want to acquire a card that be able to generate a continuous variable digital waveform. I'm evaluating the possibility of PCI-DIO-32HS, but in the description of "Continuous pattern I/O" it says that it stops after 100 MB are transferred whithout error. Does it mean that I can´t perform a variable digital waveform for a long time?
(3,340 Views)
Juan:
The DIO-32HS can transfer continuously. The description you are reading is the description for the examples used to benchmark the maximum transfer rate of the PCI-DIO-32HS. These continuous buffered examples are written so that it will stop after 100 MB of data are transferred and report back the transfer rate. This does not mean that the device can not transfer continuously.
June
(3,340 Views)
