Digital I/O
PXI-6528 Relay Set Time
PXI-6528 data sheet and specification says that its solid-state output relay's set time is a maximum of 5ms.
What is the nominal value? What is the brand and model of the relay that is used inside this board?
Thanks in advance!
(3,908 Views)
Hello Mike,
What kind of nominal value that you are looking for?
- Meadow -
LabVIEW 7.0 - 2011, Vision, RT, FPGA
TestStand 3.0 - 4.5
(3,883 Views)
typical value of the time it takes for this type of relay to close.
(3,881 Views)
Mikeee,
Why would you set up your program to fail with 50% of the relays?  Typical values are the mean time it takes all relays to switch.   Wouldn't it be preferable to wait until the worst case relay is in the commanded state before you try to do anything else dependant on the relay state?
(3,876 Views)
