Digital I/O
Port is resetting the value after DAQmxStopTask is called.
Hello? My device is PCI-6025E and I used to reset it by sending 0x00 on digital output port#0 with DAQ. It needs to be reset if power down button of VC++ software is pressed.
But after a simple testing of DAQmx, even after I sent 0x00, it automatically resets 0x00 value to 0xFF after DAQmxStopTask is called. I want to know how I can know it is 0x00 before DAQmxStopTask is executed.
I've tried to read the port #0 while writing 0x00 on it, but it hangs or it returns error; it said the port is reserved and can't read the port until the task (writing) is done.
Here is the code I tested.
 int         error=0;
 TaskHandle taskHandle=0;
 TaskHandle DItaskHandle=0;
 uInt8  data=0x00;
 char        errBuff[2048]={'\0'};
 int32  written;
 int32  read;
 uInt8  dataToRead;
 bool32  bTaskStatus;
DAQmxErrChk (DAQmxWriteDigitalU8(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,&data,&written,NULL)); //creaded 6.5.2009
DAQmxErrChk (DAQmxIsTaskDone(taskHandle, &bTaskStatus));
//DAQmxErrChk (DAQmxWaitUntilTaskDone(taskHandle, 1.5)); // 6.5.2009
if(bTaskStatus){
 ///------------------DI reading test on written port0-----------------------/// 6.5.2009
 DAQmxErrChk (DAQmxCreateTask("",&DItaskHandle));  //6.5.2009
 DAQmxErrChk (DAQmxCreateDIChan(DItaskHandle,"Dev1/port0","",DAQmx_Val_ChanForAllLines)); //6.5.2009
 DAQmxErrChk (DAQmxStartTask(DItaskHandle)); //6.5.2009
 DAQmxErrChk (DAQmxReadDigitalU32(DItaskHandle,1,10.0,DAQmx_Val_GroupByChannel,&dataToRead,1,&read,NULL)); //6.5.2009
 printf("Data acquired: 0x%X\n",dataToRead); //6.5.2009
I'm converting DAQ to DAQmx..from Parkoz.com
(3,473 Views)
Accepted by topic author anarkie
Try using the DAQmx property node to invert the Digital lines.
Depending on the whether you are configuring DI/DO use the following
int32 __CFUNC DAQmxSetDOInvertLines(TaskHandle taskHandle, const char channel[], bool32 data);
int32 __CFUNC DAQmxSetDIInvertLines(TaskHandle taskHandle, const char channel[], bool32 data);
Glenn
Glenn
(3,444 Views)
