Digital I/O
PXI 665X: Generate/Acq Clock, Strobe, Data, Trigger signals
Hallo everybody,
I'm new with Labview and NI-PXI, so sorry in advance if my question looks stupid.
In my Chassis there is (other than a PXI-8336) a PXI-6652. With these devices I have to generate and send (each on a different line) a signal timing (the protocol is fixed) composed by:
- clock signal (200 ns);
- a strobe signal;
- data signal;
- trigger signal.
Data is made up of 10 bits and the object that receives these signals waits for two triggers that can be sent in 2 different moments (I'd like to add 2 bottons, one for each trigger event).
I found severals examples that could have helped me but, for my fault, I'm still confused. There is anybody that can give me any suggestions?
Thanks a lot!
Ilaria
(3,781 Views)
Hello Illaria,
could you please answer me to the following questions in order to understand better your issue?
Can you please send me a simple schema of the connection you are implementing and a signal timing diagram?
You are writing about two triggers. What kind of execution do you want to start by triggering these triggers?Generation or acquisition and by which object?
Antonios
(3,746 Views)
