Digital I/O
PXIe-657x type of relay used to disconnect I/O channels to VHDCI connector
The high-level block diagram in the PXIe-657x training manual shows relays on the channels between the pin electronics and the VHDCI connector.  I have a situation where two PXI resources have to access the same bond pad of a die at mutually exclusive periods and I am trying to determine the impedance of the DIO channel where leakage might occur.
(1,380 Views)
Those are going to be solid-state relays and there will be leakage. I would recommend adding an external relay in your test setup to completely isolate the signals.
Santhosh
Soliton Technologies
(1,350 Views)
Accepted by RTMicrochip
Thank you, santo_13 for a very quick response to my query.  A design oversight uses the same bond pad in one set of test structures to be driven by the PXIe-6570 as the enable pin and on another set of structures that pad sources a 125nA current reference to be connected to a PXIe-4071 DMM in the automated wafer probing system.  A few nanoamps of leakage is significant so your suggestion for an external relay is the only real option.
(1,337 Views)
