10-05-2007 02:49 AM
10-09-2007 11:52 AM
10-10-2007 05:30 AM - edited 10-10-2007 05:30 AM
Setup and Hold Times
When a DAQ device samples a digital signal, the signal must remain stable for a period of time before and after the assertion of the clock edge used for timing. The amount of time before the assertion of the clock is called the setup time. The amount of time after the assertion of the clock edge is called the hold time. Refer to your device documentation for minimum setup and hold times.
Message Edited by Rob L on 10-10-2007 06:02 AM
10-10-2007 07:08 AM
Hi Rob
Thanks very much for your input, it appears there is a problem with the timing/edges of the clock, strobe and data. This is now being addressed by the hardware design team and initial results are promising. I think we can consider this investigation closed for the present time.
Cheers
Brian
10-10-2007 08:12 AM
