Digital I/O
writer.WriteMultiSamplePort
I am currently porting my VB6 app to VB.NET 2005.  I have been looking at the example under the c:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\DAQmx\Digital\Generate Values\WriteDigPort\vb My question is in my "new" code and the
writer.WriteMultiSamplePort statement.  The NI example uses the statement writer.WriteSingleSamplePort (only opening one port to write sample to).  However, since I have ports 0:7 to open and write sample to, I was not sure how to do this.  Any help or guidance much appreciated.  Thanks!
My "old" VB6 code:
                On Error GoTo ErrorHandler
                arraySizeInBytes = 8
                '  Re-initialize an array that holds the digital values to be written
                ReDim writeArray(arraySizeInBytes)
                For i = 0 To arraySizeInBytes - 1
                    writeArray(i) = chkDeviceOnePortTwo(i).CheckState
                ' Create the DAQmx task.
                DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxCreateTask("", taskHandle))
                ' Add a digital output channel to the task.
                DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxCreateDOChan(taskHandle, "Dev1/port2/line0:7", "",       NIDAQmxCAPI.DAQmxLineGrouping.DAQmx_Val_ChanForAllLines))
                ' Start the task running, and write to the digital lines.
                DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxStartTask(taskHandle))
                DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxWriteDigitalLines(taskHandle, 1, True, 10#, NIDAQmxCAPI.DAQmxFillMode.DAQmx_Val_GroupByChannel, writeArray(0), sampsPerChanWritten, 0))
                ' All done!
                StopTask()
                Exit Sub
        ErrorHandler:
                If taskIsRunning = True Then
                    NIDAQmxCAPI.DAQmx.DAQmxStopTask(taskHandle)
                    DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxStopTask(taskHandle))
                    DAQmxErrChk(NationalInstruments.DAQmx.TaskAction.Stop)
                    NIDAQmxCAPI.DAQmx.DAQmxClearTask(taskHandle)
                    taskIsRunning = False
                End If
                MsgBox("Error: " & Err.Number & " " & Err.Description,  , "Error")
My "new" code:
        Windows.Forms.Cursor.Current = Cursors.WaitCursor
        Try
            '  Create an Digital Output channel and name it.
            digitalWriteTask.DOChannels.CreateChannel("Dev1/port2/line0:7", "", _
                ChannelLineGrouping.OneChannelForAllLines)
            '  Write digital port data. WriteDigitalSingChanSingSampPort writes a single sample
            '  of digital data on demand, so no timeout is necessary.
            Dim writer As DigitalSingleChannelWriter = New DigitalSingleChannelWriter(digitalWriteTask.Stream)
            ''''''writer.WriteSingleSamplePort(True, Decimal.ToUInt32(dataToWriteNumericUpDown.Value))
            writer.WriteMultiSamplePort(True, Decimal.ToUInt32(dataToWriteNumericUpDown.Value))
        Catch ex As System.Exception
            MessageBox.Show(ex.Message)
        Finally
            System.Windows.Forms.Cursor.Current = Cursors.Default
            digitalWriteTask.Dispose()
        End Try
(3,939 Views)
Hi jsrMN,
You meantion that you are using Ports 0:7 but in your "old" code you are using port2/line0:7. If this former is a typo then I believe the appropiate example to look at would be writedigchan which can be found.
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0\Digital\Generate Values\WriteDigChan\vb
This example uses writer.WriteSingleSampleMultiLine, which will allow you to write different values to each line in the port.
I hope this helps
JaceD
Signal Sources Product Support Engineer
(3,920 Views)
