Digital I/O
Questions for NI9401
Hi everyone,
I have two questions regarding NI9401:
1. Is there a signal breakout board for NI9401 module (for separating channels from the d-sub connector) available for purchase, or we need to design our own breakout board?
2. Does anyone have experience using NI9401 to input to Power Integrations gate driver core?
I look forward to your reply, thanks!
(1,606 Views)
@JustinZZJ wrote:
Hi everyone,
1. I see a recommendation for a NI-9924 terminal block.
2. My main concern would be the current needed for whatever device you are using.  The NI-9401 is rated for a maximum output current (to maintain TTL levels) of 2mA.
GCentral
(1,586 Views)
Thank you so much! This is very helpful.
The datasheet for gate driver says the input bias current is 190 uA and turn-on threshold is 2.6 V. Do you think NI9401 is suitable? Is there anything else that I should pay attention to?
(1,545 Views)
Sounds like you should be just fine.
GCentral
(1,539 Views)
Thank you!
(1,534 Views)
