Digital I/O
Read Binary File To LABVIEW Matrix
Hi Hal,
Thank you for your replay.
I have made the above modifications. I still can't write the data from the file.
I am getting the following error at the second "Write",
---------------------------------------------------------------------------------------------Error Remark------------------------------------------------------------------------------------------------------
Attempted to write a sample beyond the final sample generated. The generation has stopped, therefore the sample specified by the combination of position and offset will never be available.
Specify a position and offset which selects a sample up to, but not beyond, the final sample generated. The final sample generated can be determined by querying the total samples generated after a generation has stopped.
Attempted to Write Sample: 48
Property: RelativeTo
Corresponding Value: Current Write Position
I added my application. ( The sub vi's are in the previous post)
Best Regards,
Nir
Message 11 of 14
(1,594 Views)
Hi Nir,
I'm looking into your issue right now.  It may not be possible to trigger off of an 84khz clock in software. I apologize for saying that would work, but I did not originally think that your external clock would be at that high of a rate.  I will post another reply when I have more information.  Thank you for your patience on this issue.
Hal L.
Message 12 of 14
(1,575 Views)
HI,
i'm using PCI 6534 Card .i want to read the serial data on the external clock
i have used DAQ MAX but i am unable to read from external clock as input to read serial data instead of that im using /Dev1/Dig0/SampleClockTimebase AS a clock source but i'm not sure that reads at it's +ve edge(rising)
since i want to use external clock source
please tell me how to proceed for this application
please reply me
mandar
(see attachment)
Message 13 of 14
(1,378 Views)
Hello mandar,
It appears that this issue is being discussed in another forum here. Please refer to that forum for more information.
Matt Anderson
Hardware Services Marketing Manager
Message 14 of 14
(1,364 Views)
