Digital I/O
Read digital inputs from 6 IO lines
   I don't know if this question has been posted but I am using a M-series 6289 Multifunctional DAQ card currently under CVI. I tried to read digital inputs at 4 Hz from 6 lines at the same time. However, it seems that I missed some digital signals which results in inconsistency. In CVI, I create individual task to read samples from each IO line, which is executed under a "for" loop. Hence, I wonder if there is a more efficient method to perform the same task of reading inputs.
YB
Message Edited by evangel55 on 10-20-2006 09:38 AM
(3,639 Views)
Is there a CVI supported command to read the entire port at once? Then just mask and extract the line data bits you need to operate on.
(3,631 Views)
Hi evangel55,
Which DAQmx function are you currently using?
Check out the NI-DAQmx C Reference Help.  Based on your post, I think that the DAQmxWriteDigitalLines would work for your purposes.  The description is shown below.
DAQmxReadDigitalLines
int32 DAQmxReadDigitalLines (TaskHandle taskHandle, int32 numSampsPerChan, float64 timeout, bool32 fillMode, uInt8 readArray[], uInt32 arraySizeInBytes, int32 *sampsPerChanRead, int32 *numBytesPerSamp, bool32 *reserved);
Purpose:  Reads multiple samples from each digital line in a task. Each line in a channel gets one byte per sample.
I hope this helps, but if this is what you’re currently using or if you're doing something different, then I’d probably need more info – it may help to post the code with your for loop.
Ed W.
(3,588 Views)
Sorry, the last post should read
Ed. W
(3,588 Views)
