Digital I/O
efficient way of writing multiple waveforms to pxi 6561
I wanted to know if there is a efficient way to write multiple waveforms to the pxi 6561. Suppose I have several waveforms stored as .hws in a file, and I want to write all of them to the pxi 6561. I am now writing them one by one, by retrieving each waveform and writing them to the device, but I wanted to know if there is a more efficient way of doing this built in labview. I suppose later I could build my own subvi to do this if there isn't one already built
Thank you
(3,239 Views)
Hi Timothy -
The "Write Named Waveform" VI is the only one provided with the HSDIO driver for adding waveforms to onboard memory.  If you need to do a batch process, it should be as simple as writing an error-checking loop to call the function repeatedly.
David Staab, CLA
Staff Systems Engineer
(3,219 Views)
