Digital I/O
Reg: USB 6002
I Have a USB 6002 Card. In that card i want to know that what is the max & min range of voltage&current generated in DO.
i need to know about the 1. Active region 2. Open collector i am not aware of the detail that is mentioned in the Data sheet
(2,598 Views)
Accepted by topic author visam
You need to look at the spec sheet in the manual section, not the data sheet.
https://www.ni.com/docs/en-US/bundle/usb-6002-specs/resource/374371a.pdf
Sorry about the non-link.  The message board is not letting me insert a link.
(2,522 Views)
