10-22-2019 08:11 AM
I Have a USB 6002 Card. In that card i want to know that what is the max & min range of voltage¤t generated in DO.
i need to know about the 1. Active region 2. Open collector i am not aware of the detail that is mentioned in the Data sheet
Solved! Go to Solution.
11-12-2019
10:51 AM
- last edited on
09-26-2025
02:33 PM
by
Content Cleaner
You need to look at the spec sheet in the manual section, not the data sheet.
https://www.ni.com/docs/en-US/bundle/usb-6002-specs/resource/374371a.pdf
Sorry about the non-link. The message board is not letting me insert a link.
