Digital I/O
Remanent data storage on RT target.
Hello everyone,
An RT target (desktop PC) is running a machine vision inspection. The number of inspected and failed parts are counted. My problem is to keep this data in case of power loss.
I guess that my only chance is to write this two values to harddisk from time to time so in case of power loos or pc restart I can read the last written values and use them as initial values.
If we don't take into account access time to harddisk, I am concern about the physical stress to HD of re-writing these  two values over and over again.
- Am I writing to the same physical sectors of the HD everytime?. I think this can be dangerous.
- How often should  I save the data?
Any alternative idea is wellcome.
Thanks in advance.
(4,109 Views)
What is the physical sector mean?
The datarecording to hard disk can be done in a low priority loop than in the loop that does primary task.  Just pass the data in a queue and write the data in other loop.  Take care to flush the data in regular intervals @ 5000ms approx to ensure that data is written into hard drive.
Hope this helps.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(4,091 Views)
It's you are writing in the same physical sector if you are REwriting the same amount of data (same data type, format and value range) in a file every XXX seconds. If you want to be sure you are writing in different HD position, delete your actual file and generate a new one each XXX minutes.
Another option can be create a logging of values instead of just a single value. I mean, write a list of data instead of a single data in the file. After XXX lines, open a new file and delete the old one (or just delete the old one and star again).
(4,087 Views)
It's pretty hard to wear down a harddisk by re-writing the same sector. Harddisks also run sanity checks and will automatically exclude defective sectors, so the next re-write would go to a sane sector if the existing one appears to be damaged.
Herbert
(4,077 Views)
