Digital I/O
Replacement for AT-DIO-32F
I have an old machine using an AT-DIO-32F card.  I would like to upgrade the machine and also the DIO card. What would be a similar card to the AT-DIO-32F?  There is code already written for the 32F and I would like to keep as much as possible, along with connections, etc.
(3,524 Views)
Hi greenavenger,
The AT-DIO-32HS, also known as the 6533 family, is almost a direct replacement for the AT-DIO-32F. The AT-DIO-32HS performs all the functions of the AT-DIO-32F and also adds new functionality, you should not have to make any changes to your code unless you are using the IN1, OUT1, IN2, OUT2 lines which are not available in the AT-DIO-32HS.
I hope this helps!
Erik J
(3,506 Views)
